Similar to the workflow for stitching/welding edges, I believe the workflow for stitching/welding vertices can be improved. SubD modeling is repetitive and minimizing keyboard strokes greatly improves modeling speed.
Steps required in Rhino to stitch/weld two vertices to the average location.
-Stitch
-Select Vertex1
-Enter
-Select Vertex2
-Enter
-Enter again to accept default average location
Steps required in T-Splines to stitch/weld two vertices to the average location
-Window select two vertices
-Hit Z on the keyboard
Steps required in Rhino to stitch/weld two vertices to either first or second location
-Stitch
-Select Vertex1
-Enter
-Select Vertex2
-Enter
-Select First or Second in command line
Steps required in T-Splines to stitch/weld two vertices to either first or second location
-Hit Z on keyboard
-Select Vertex1
-Select Vertex2 (First selected Vertex jumps to second selected Vertex)
While I’m not suggesting copying the T-Splines commands minimizing the number of steps required to perform tasks in SubD modeling is really, really helpful.
Thanks,
Mark.
