How to weld vertices (mesh, subd)?
Hello!
I can’t believe I have to ask this: what’s the right way to simply weld vertices on a joined mesh?
I’d like to weld those subd corner verts - tried WeldVertices and WeldEdge. Not working. Verts still are apart:
And shouldn’t these commands have a tolerance parameter?
Thanks!!
Best regards
Eugen
I believe you’re looking for the command _Stitch.
Aaah… yes! Works, Thanks a lot!!
However, is there another command that allows for welding, say, the verts of a whole edge loop or even the whole object without having to work through them 2by2?
I remember the way the ‘Weld’ modifier in 3ds max works. It just has a tolerance parameter, and any pairs that fall under the tolerance get welded.
Different story here, right?
Run -_Stitch before you make any selection. You’ll be able to select edge loops. You first select the edges on one side. Then you select the edges on the other side.
stitch_edges
Perfect, thank you very much!!
