First good morning everyone!
I’m a beginner in GH and esou with a big problem.
I need to distort a Hex grid to have the same effect as the attached image, and I have no idea how to do it.
Can someone please help me with this?
Hello Uggerister,
I would recommend you the site generativelandscapes.wordpress.com . Besides other great tutorials, there is a tutorial about “magnetic” fields in Grasshopper.
So the first step would be to generate a field to distort the control points ( vertices , if it is a mesh), after that you can generate your new geometry with the new points.
I hope I could help you,
greetings,
Bumaye
Thank you Bumaye!
I’ll check immediately!
Check this as well. it could be a start for you. Iterating Maelstrom several times(inside a cluster) will let you get the desired result you want.
Maelstrom Cluster_re.gh (10.8 KB)
Fantastic too, were several valuable examples. Thank you again.
Is Maelstrom a plugin? I did not find it on GH
You can find theMaelstrom in Rhino 6 GH1.0 in the Transform tab–>Morph–>Maelstrom
HS_Kim rotates the geometry in the cluster.
So after the maelstrom, you can rotate the geometry back (with the same angle and center) back to the position.
greetings
