Speed Learning Rhino
If the icons for commands also existed in the menus, along side each pulldown entry, it would help people learn Rhino. Apparently, there already space for something there.
If the command command-line name also existed in the balloon help, it would speed that as well. In other words, you could mouse over an icon, and see the typeable command.
Thanks for the consideration.
hey Brenda, sorry for being very late to the party here- in the panels on the right, if you enable the help panel then check “auto update” rhino will display the help for each tool or command you use as you use it.
not sure if that’s helpful, but wanted to make sure you knew about that function.
