Slow Object Selection in Rendered Viewport Mode
Hello there,
I recently got a new laptop with a reasonably good configuration. However, it takes about 7 seconds to select an object when using a rendered display mode in the viewport. This happens consistently with a fairly large file containing numerous blocks and some linked files, though it works fine with other display modes. The lag occurs with any type of object.
Below is the result of SystemInfo. Are there any suspicious details in it? It feels like my old laptop performed better, which makes me think there might be an underlying issue.
Thanks,
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 31Gb)
Primary display: Intel(R) Arc™ Graphics (Intel) Memory: 128MB, Driver date: 3-27-2024 (M-D-Y).
Primary OpenGL: NVIDIA RTX 3500 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 12-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.50
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-11-2024
Driver Version: 31.0.15.5350
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Users\HiroyukiTsukui\AppData\Local\Programs\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.24138.1238
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp “BlockEdit” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
is the problem happening in Rhino itself or in Enscape?
if you disable Enscape does the problem get better?
does this help?
