Delay when selecting object R7
Hi all,
I’m working on a 72mo file and sometime double.
Quite often when selecting object I noticed a delay of a second or less.
I do not have this delay with lighter file and understand maybe my old computer feature is the key
My graphic driver is up to date, and while working with,task manager display a memory use at 49% max,cpu at 9% and graphic gpu at 7%.
Mesh is set to “jagged and faster”
Do you have any idea how to solve that delay when selecting?
Thanks
Here is my system info:
Rhino 7 SR34 2023-9-24
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Cpu : Intel 4770K
Primary display and OpenGL: NVIDIA GeForce GTX 1080 (NVidia) Memory: 8GB, Driver date: 10-11-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 545.84
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-11-2023
Driver Version: 31.0.15.4584
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Hi -
Please post the entire system information!
Apart from that, we’d need a 3dm file to see if we can reproduce the issue. You can use Rhino - Upload to Support to upload a large file.
Hi
Well I have paste my complete system info from rhino, I think.
The fact is that I still have lags selecting with single primitive displayed.
:confused:
What do you need I could forget?
Hi Jean-Christian -
You seem to have deleted a few items at the top, added a Cpu line, and, most importantly, have left out all the plug-in information?
That doesn’t tell us if very many other objects are merely out of view or hidden; or if you have started a new file from a factory-default template and only created a single box. As such, the 3dm file that you are testing with would be good to have.
Apart from that, could you post a screenshot of the entire Rhino UI?
Hi
It seems my problem has gone, I made a “save small” and re-opened file, atm no delay.
I’ll get you up to date when I’ll be sure it’s solved
Problem solved:
“BoxEdit” shelf enable= delay
Same thing on both of my PC
Thx
