Sky background not visible
Test render outdoor scene: Vray 5/Rhino 7.
Why does the rendered scene contemplate the blue of the sky, but the saved image (png file) erases the sky and sets a white background?
Could someone help me? maybe in the Vray panel you need to set something?
Try saving as a JPEG.
For PNG you need a dome light.
Glenn
I’ll try, thanks. :wink:
I forgot to ask if you have dropped a Vray sky texture in the environment>background texture slot (it’s on the page with camera, render output, etc) and set up Rhino Document Sun?
Glenn
Two other ways:
  • use the free image browser XnView - you can enable/disable the alpha of a png and remove the alpha, so that the background is visible again
  • in V-Ray you can set an output path and disable the alpha, but all images will have the same name.
It’s a pity that the developers was not able to allow to simple render without alpha, I miss it often too.
Saving from VFB manually will always output an alpha channel. It is a separate component, and it currently has no option to not write the alpha out. RenderOutput is the only way to remove the alpha
Thank you all.
I checked in the Vray 5 control panel.
I can’t see all those options regarding the alpha channel:
Immagine 2021-05-05 095534
“Image option”, where is?
you have to put a file name. The file name extension will determine the kind of the additional options to show
Ok. Perfect! :+1:
Hi, just started this account to ask you on thing. I have downloaded the XnView and enabled the alpha chanel. How do I save the image (in png) with the alpha on?
I hope I’m not too late haha
Hi Raul,
no problem, I’m still here. In XnView double click on the image and look at the menu …
… and save for example per Ctrl+S.
You can also use the batch tool for several selected files.
