I used the Mecsoft-Font-1 and the Rhss single line fonts many times before in single line engraving of panels. Now the fonts (using Text object) do not come up as single line, but as a broken ended double line font. Yes, engraving font is ticked in the box.
Oddly, when using the Rhss font, the very first time the font is entered, AFTER a Rhino restart, the font is correct ( single line), but not sized correctly.
Enter a second text line after that, and it is all double again.
Both these fonts used to work - 6 months ago I last did this.
My Rhino version -
Actually, I believe the actual font is not the problem..
It seems that Rhino ignores the actual font selected, or if not, just uses the same font for each of the three selections.
This image shows a plain text font, top line, and the next three are
SLF-RHN
RhSS
Mecsoft_font-1
The result is identical for all three..
What gives?
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 9.0.6
Computer platform: DESKTOP
Standard graphics configuration using OpenGL
Primary display: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 5-12-2025 (M-D-Y). OpenGL(4.6.0 NVIDIA 573.24)
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 5-12-2025 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-12-2025
Driver Version: 32.0.15.7324
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.25175.6305
C:\Program Files\Rhino 9 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 9.0.25175.6305
I have sorted it - but it is a Rhino Bug for sure…
enter Text Object,
Select any of the three fonts
enter the desired text.
Then click capital A ( right of the Font line) and then the font placed is single line!
And every new text place after that remains single line…
Rhino is fun..
I haven’t replicated your problem - I wondered if creating an Arial object first made a difference but it didn’t - but I do see that once you have used the MecSoft font, the Engraving font box is ticked and greyed out so you can no longer unset it, even by selecting a new font or forcing a reformat with the ‘A’. A companion bug to yours.
You are correct..
If I exit Rhino and start again, the problem is present.
Select mecsoft font - the engraving font tick box is bold, not greyed.
Any text then placed is double line.
Click on ‘A’ to force upper case ( or ‘a’ for lower case..)
Then all text places as single line and the engraving font tick box is greyed out thereafter and further placed text is single line.
Ideally the CNC font should be a combination of MECSOFT and TXT. Mecsoft, when exported to DXF is converted to polylines with numerous short segments defining the curves. This bogs down the robot. A single line text with the blockiness of TXT would solve this.
