How single line engraving fonts display in the TextObject command
I need to create another single line engraving font and I’ve been able to take the SLF RHN Architect font that ships with Rhino 7 and make some changes using FontForge. All of that worked out just fine. I was able to rename the font into something our people will easily remember. That was achievable through FontForge as well. However, I don’t like the way it displays in the TextObject window. It’s almost unreadable. But the SLF RHN Architect font that ships with Rhino displays very legibly. Does anyone have an idea how this was accomplished?
Any suggestions would be appreciated.
Thanks,
Dan
Hi Dan,
Rhino keeps details of McNeel acknowledged single line fonts, so that may be a factor. Otherwise it may be that fontforge messes with line direction when editing your font. If you temporarily rename the working font and apply its name to your edited version you should find out which problem you have. From memory, it was @stevebaer who told me about the Rhino sigle line font table, if not he’ll likely know who the McNeel font guru is…
HTH
Jeremy
Hi Jeremy,
I did as you suggested even before making the original post. As soon as I rename the original font it displays wonky in the TextObject command. Interestingly, I have some Delcam single line engraving fonts that also displays the same. I’m curious as to how McNeel stopped the SLF-RHN Architect font from displaying like that too.
Thanks,
Dan
Hi Dan,
I dug out the original thread I remembered. This is Steve’s post: Font and Single Line Font Requests - #6 by stevebaer
Regards
Jeremy
Hi Jeremy,
Looks like this doesn’t have a simple solution. Thanks for the link.
Dan
