Since I upgraded V-Ray to version 3.0 (from 2.0) I have severe performance issues with Rhino. It makes Rhino crash occassionaly, while Rhino used to be one of the most stable and safe programs I work with.
Rhino seems to work ‘slower’, consuming more memory from my computer. Commands react less quickly.
Do more people have these issues and are they known with the developers? I reported already some crashes.
Not sure what’s going on but I have problems with V-Ray 3 also. I normally work in Thea, but when I set current renderer to V-Ray, my fans start howling - even though I haven’t done anything other than change the renderer. Sometimes Rhino will get stuck and I have to force close it. This is almost always right after rendering something with V-Ray.
Also, I seem to have quite a number of V-Ray / Chaos processes going simultaneously as seen in my task manager. Maybe that’s as it should be but it seems strange.
I’ve had a few crashes using V-Ray v3, very unusual for Rhino to crash so I suspect it is V-Ray. I haven’t used the more recent release yet so hopefully the problems are being fixed.
I haven’t had it crash unless I’m actually using V-Ray. I leave V-Ray set as my default renderer and can work in Rhino without problem. The only issues I’ve had are a few crashes when I’m applying materials or setting up a render.
