Just started using SubD in rhino and for some reason I cant select the vertices with ctrl+shift select to be able to edit the points. I can if i use the show edit points.
Anyone come across this before? Dont all shout at once
can you do a screen recording showing this behavior? Itās working well here, and I want to make sure Iām understanding your issue correctly.
Will have a look on the morning. Pretty sure itās not checked. I was using the filters for the control points though. Will get back to you.
OK found a solution, i dont know if its a problem to
will you post your systeminfo from rhino? Iām curious about your graphics card sitch-
That was my thought as well. I upgraded the driver on the card this morning against Dellās confirmed certified drivers . But I didnāt check the box in options prior to the driver change. Will send the info. Does my system info need to be private?
no, simply run the systeminfo command in rhino and copy/paste the report.
Other than your machine name which you can redact out if you want, there is no personal info in the report.
If you see anything, can you let me know, many thanks.
Rhino 7 SR2 2021-1-21 (Rhino 7, 7.2.21021.07001, Git hash:master @ 96ff97351fbdf5d2acdeaf781aea1577f2ff60f7)
License type: Commercial, build 2021-01-21
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 4GB, Driver date: 1-22-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.40
> Integrated acclerated graphics device with 4 adapter port(s)
- Windows Main Display is laptopās integrated screen or built-in port
Secondary graphics devices.
IntelĀ® UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 5-19-2020 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-22-2021
Driver Version: 27.21.14.6140
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\5.0.1.0\XNurbsRhino.rhp āXNurbsā
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp āV-Ray for Rhinoā
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp āCommandsā 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp āRenderer Development Kitā
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp āRhinoScriptā
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp āRhino Renderā 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp āRDK_EtoUIā 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp āRenderer Development Kit UIā
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp āSnapshotsā
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp āRhinoCyclesā 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp āToolbarsā 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp ā3Dconnexion 3D Mouseā
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp āDisplacementā
All looks ok,
peek at this thread, your machine reports non hybrid, but itās worth following the steps-
also always a good idea to set your nvidia 3d settings to this -
Many thanks.
Still dosnt work with ctrl+shift select , but does work with shift select only with the sub-objects on then use the filters to select points and disable faces inside the subD geometry.
thatās oddā¦ any custom stuff? mouse, keyboard, gamer add onās etc?
It may be worth trying a repair on your rhino install- (or help>check for updates)
Good point. I have a logi Bluetooth keyboard and mouse logitech mx master 3. Moghtvtry and save settings and do a install again. Do I just download from rihno the latest update.
Is thier a clean uninstall process. Might look for one. Hopefully the reinstall will sort it .
Thanks very much
installing the updates is good enough, Iād look at any custom bits in your mouse/ keyboard chainā¦
I have the same issue.
I tried installing Logi software, but Ctrl+Shift is not selecting SubD.
Did you find any solution?
I have the latest SR17
Thank you
RenƩ Medel
Not really, learned blender instead
Hahaā¦ well, I will stick to Rhino.
But Crtl+Shift is driving me crazy.
Thanks anyway
@theoutside Hi Kyle,
Since you are the SubD masterā¦ Have you heard about how to set the Ctrl+Shift combo in this Logi Mx keyboard?
Thank you
