Shaded” mode acting like “Ghosted” mode in Rhino 8?
Hi!
My Rhino 8 suddenly started behaving strangely, as Shaded mode became very similar to Ghosted mode. I have removed the installation and installed the app again, but the problem is still there. The model works as expected in Rhino 7. Any suggestions on how to revert the Shaded mode to its original function?
Is this with only one specific model or with all models like just a simple box?
If it happens with all geometry, if you go into Options>View>Display modes and find Shaded view in the list and hit the “Restore Defaults” button, does this fix anything?
Also, maybe you need to update your video drivers… Can you run SystemInfo in Rhino and post the results here?
Without a before/after screenshot, it’s hard to say - but when, while using the Shaded display mode, curves appear in front of surfaces, use ClearDrawOrder.
are your layer colors fully opaque?
pls run SystemInfo in Rhino and post back the results, as well as a model that shows the issue.
No effect.
Rhino 8 SR23 2025-9-8 (Rhino 8, 8.23.25251.13001, Git hash:master @ e75a9d62e23cc6f52d4ef68eb7eda9f8da9b6cd9)
License type: Educational, build 2025-09-08
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.20
Primary display and OpenGL: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9664
Integrated graphics device with 3 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
    Primary OpenGL: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9664
Integrated (slow!) graphics device with 3 adapter port(s)
Secondary graphics devices.
Radeon ™ 530 (AMD) Memory: 4GB, Driver date: 8-2-2022 (M-D-Y).
Integrated accelerated graphics device (shares primary device ports)
  • This device is not being used
ATTENTION:
Laptop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9664
Driver Date: 6-1-2021
Driver Version: 27.20.100.9664
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.2.0
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.23.25251.13001
Since this happened, it is on all models.
Restore option worked!
Thanks, Helvetosaur!
