Since today the Shaded viewport of my Rhino 7 started to render the objects in the scene as if they are made of a mirror material. Seems like Rhino uses the viewport to grab a real-time environment map to simulate a mirror finish. I haven’t done any changes or updates of my Rhino recently.
Here is a video that shows the issue:
Still no solution to this bug?
pascal
(Pascal Golay)
July 24, 2023, 1:56pm
3
Hi Bobi - can you please export the display mode and post it? Then, try restoring defaults…
Hi Pascal, here is the Shaded viewport. Note that I haven’t made any changes to any of my viewport modes in the recent weeks, yet the issue happened just yesterday.
Shaded.ini (13.9 KB)
pascal
(Pascal Golay)
July 24, 2023, 2:43pm
5
Yeah… no such interesting action here… I guess we’ll need the output from SystemInfo as well.
Sure, here you go:
Rhino 7 SR30 2023-6-12 (Rhino 7, 7.30.23163.13001, Git hash:master @ f695e494df78377a81b2b95edb99c6067e324b33)
License type: Commercial, build 2023-06-12
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 5-24-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 535.98
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-24-2023
Driver Version: 31.0.15.3598
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp "AnimationTools"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp "Legacy Rhino Render"
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
pascal
(Pascal Golay)
July 24, 2023, 11:55pm
7
Hi Bobi - thanks- did resetting to defaults do anything?
Unfortunately, resetting did not solved the issue.
pascal
(Pascal Golay)
July 25, 2023, 12:00am
9
@jeff - any idea what might be causing this? So far I cannot repeat it Bobi’s shaded display shopws a sort of picture of the objects themselves as a reflection …
I think that I might have the answer, as I mentioned in another topic just a moment ago:
Hi @Gijs , seems like I forgot to reply here earlier. I just discovered the reason why I see that strange bug. It happened again now when I did the following steps:
I removed a custom display mode from Rhino settings > View > Display modes > Delete. Once I did that, I forgot to press the “OK” button at the bottom to close the pop-up window!
Then I deleted the *.ini file of the same display mode from the folder where it was saved, while it was still active in the viewport in Rhino 7 (since …
