Shaded display mode appears dark when opening file
Hello!
Everytime I open a Rhino file (I always work in shaded mode) all the surfaces appear dark.
I have to change the mode to rendered and back to shaded and the problem gets fixed.
Attaching screenshots before and after I do the shaded>rendered>shaded fix.
I’m running the latest version of Rhino, but i’ve had this problem in previous versions as well.
Thank you in advance
Yiannis
Hi Yiannis -
Please run the Rhino SystemInfo command and copy-paste the output here.
Hi Wim
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Commercial, build 2024-09-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 48GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.2.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
Thanks, Yiannis -
On paper, that looks fine.
Just to be clear… When you start a new file from a factory-default template and create a simple box. Put the perspective viewport in the factory-default Shaded display mode. Save and close the file. When you then launch Rhino and open that file, do all surfaces appear dark?
With factory-default Shaded display mode, No it doesn’t happen. With my customised Shaded display mode it happens always.
Trying these steps I found out that the problem occurs when the shaded display mode’s Lighting method is set to ambient occlusion or scene lighting, and the Use advanced GPU lighting in checked. Going shaded>rendered>shaded still fixes the problem every time.
Still, I prefer to set it to ambient occlusion, because it doesn’t distort the surface colors as much (highlights-shadows) and although it’s similar to no lighting, the overall brightness is adjustable.
Can you export and send your shaded mode so we can have a look?
Shaded_Yiannis.ini (14.7 KB)
I can reproduce the behavior here.
RH-84129 Display mode does not load correctly
Thank you Gijs, Wim, for looking into it.
Have a pleasant week!
I’ll fix this…but it seems somewhat contradicting to have Ambient Occlusion ON but then also have Shadows OFF… What’s the point? Why not just set the lighting scheme to “No Lighting”?
-J
