I can’t set dynamic display usage → display object’s bounding box, when I pan in view, no box on display
It will appear when you run RotateView and Pan .
the default shade mode of v8 is not work, the copy of shade mode import form v6 is work…, why? Version 8 SR22 (8.22.25217.12451, 2025-08-05)
I tested it with the defult shade mode of V8, it works fine.
Please run SystemInfo in the command line of Rhino 8 and past all popup contents here. Thank you.
Thank you very much!
Rhino 8 SR22 2025-8-5 (Rhino 8, 8.22.25217.12451,
License type: Commercial, build 2025-08-05
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4080 SUPER (NVidia) Memory: 16GB, Driver date: 3-14-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.83
Accelerated graphics device with 4 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 3-14-2025 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-14-2025
Driver Version: 32.0.15.7283
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
I noticed you have two graphics cards. Could you try disabling one of them and then test again? Thank you.
How can I disable one in rhino?
Thank you for your reply
I tried it, but the problem is no changing
Hi l1407 -
Does deleting the Shaded display mode in the list of display modes and then restarting Rhino make a difference?
thank you very much , it worked
, why?![]()
