Selection bug? offset to the left and up
Hi, I was excited to use the “test metal” command in the new rhino WIP. I found an odd bug that makes it unusable for me. I cannot select where my mouse is resting. Its offset to the left and up. I made a screen recording. It works in openGL but not after running “testmetal”.
Hi Jack -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 8 SR0 2022-9-6 (Rhino WIP, 8.0.22249.12306, Git hash:master @ 40d87b6e847c6c827f8fc10401ce04883ecdfa80)
License type: Commercial, build 2022-09-06
License details: Cloud Zoo
Expires on: 2022-10-21
Apple macOS Version 12.2 (Build 21D49) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro18,2
Language: en-NO (MacOS default)
Apple M1 Max (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 21845 MB
Graphics: Apple M1 Max
Displays: Unknown (108dpi 1x), Unknown (255dpi 2x)
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Thunderbolt Display (2560 x 1440 @ 60.00Hz)
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
Apple Inc.: Apple Thunderbolt Display
Apple Inc.: FaceTime HD Camera (Display)
Apple Inc.: Display Audio
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.22249.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Constraints.rhp “Constraints” 8.0.22249.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConstraintsUI.rhp “Constraints UI” 8.0.22249.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.22249.12306
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.22249.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.22249.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22249.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.22249.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22249.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.22249.12306
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.22249.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.22249.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.22249.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.22249.12306
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.22249.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp “RhinoCPython” 8.0.22249.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.22249.12306
Thanks, Jack -
Could you please update to the current version of macOS and check if that makes this issue go away?
Hi Wim, sorry. I’m stuck on OSX 12.2 until dropbox fixes a problem in its software. :upside_down_face:
It’s an annoying bug because with Rhino 8 WIP and metal, i noticed a seriously great performance increase, so I really would prefer to use it.
Hi Jack -
The SystemInfo shows that you have an external display connected. Are you running Rhino on that external display? If so, does it make a difference if you run that on the laptop’s display? What happens when you disconnect that external display?
You nailed it. It works perfectly on the macbook display when the monitor is disconnected, but is offset on the thunderbolt display. Even when the window is moved between displays it works on the macbook and not the other. Very odd.
Thanks for confirming that, Jack.
We have this issue on our list as RH-70252 Display Metal: Mouse input is offset from cursor position
