Hello! Can’t find similar issue here. See enclosed screen recording of Layouts viewport. Only when testmetal enabled. OsX 13.2, macbook 16" M2 chip. There is no difference if external monitor connected, but it looks not exactly same. Sometimes hatches keep right position. Any file do the same. Ther is also issue, that legacy mode very slow with large files, but it’s another topic…
b
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
yep, this is on my bug list as something that needs to be fixed for metal
Hi Here you are)!
b
Rhino 8 SR0 2023-2-8 (Rhino WIP, 8.0.23039.08306, Git hash:master @ 101d9fbfd06b4ea3dce4ec17627706929f68ec0c)
License type: Commercial, build 2023-02-08
License details: Cloud Zoo
Expires on: 2023-03-25
Apple macOS Version 13.2 (Build 22D49) (Physical RAM: 64Gb)
Mac Model Identifier: Mac14,6
Language: en-CZ (MacOS default)
Apple M2 Max (OpenGL ver:4.1 Metal - 83)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 48 GB
Graphics: Apple M2 Max
Displays: Unknown (255dpi 2x)
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp “MPlane” 8.0.23039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.23039.8306
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.0.23039.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.23039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp “RhinoRoslyn” 8.0.23039.8306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConstraintsUI.rhp “Constraints UI” 8.0.23039.8306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.23039.8306
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.23039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.23039.8306
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.23039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp “RhinoCPython” 8.0.23039.8306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.23039.8306
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.23039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.23039.8306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.23039.8306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23039.8306
Thats great)! Another similar bug what I’m sure you know about is… When you move whole window of Rhino to another display, cursor has a large offset. I mean when you click or make selection, it’s not uder cursor, but in another area of screen. This happens “randomly”, not every time the whole Rhino is moved to another display. If you want some more info, hardware setup, etc, let me know…
b
