Hi all,
I’m working with a Revit model that has many design options for a given project. And I will like to select objects from Revit onto rhino from a specific option. Is this possible with Rhino inside?
Thank you
Hi all,
Thank you
Where can I find Document Design Options Node?
I can see Document Links I expect to be here or it is somewhere else?
are you planning to add one here ? or we need to still add manually tp User Object
@michaldengusiak See this please. There are downloadable python components on the guide. We will convert them to native GH components soon
@eirannejad yes as you can see on image I am using this UserObject problem is it does not work correctly for me
Does something like this work?
As @eirannejad said a 'Query Design Options" component is planned.
@kike thanks a lot it works great inside live Architect project
however, how can I get it working via the linked model?
I am missing the ability to connect Document to Design options so can filter by linked model, design option and category… I can not see my Design Options from Linked model
All the Query components have an optional Document parameter.
Zoom in on the component a plus sign should appear at the top to allow you to add it.
