Rhino inside revite, help me please
Why i can’t select revit elements created by rhino ,please
hard to say without any further information, but I´d guess the object is pinned (default RiR settings).
You want to check your lower right corner of Revit window, where selection filters are located as in pic below …
2024-02-16 13_23_20-
If your filter for pinned objects shows a red cross, click it and uncheck the cross. Did it help?
Regards,
Pavel
Hello
Thanks for the reply…
.there is the same problem
Hi Liefe Dj, Help us help you!
Like Pavel mentioned, we’ll need more info to be able to help.
Specific version info is always good to know.
In this case how you are creating the objects and the Revit environment (worksets, phases, …) are still unknown. Can you post your files (Revit, Rhino & GH?) Thanks
