I split the overall mesh in Modo since the edge selection tools are superb. But is there some similiar approach in Rhino for Meshes when e.g. you select 2 edges in one continuous row? Thanks for your advice!
No I don’t think so, Rhino doesn’t have edge loop or edge ring selection options for polygonal meshes. I think these are mainly useful on quad models which get a subdivision surface modifier. Rhino may support something like this once the sub-d project gets more attention but right now Rhino is more geared to working with the random tri meshes you’d get from scan data.
@BrianJ this would be awesome and Rhino the clear powerhouse for product design. As approaches like Tsplines and Claydoo are very limited. Thanks for chiming in!
Hi @hannesgrebin – after about 3 years
There’s now a SelEdgeLoop command in Rhino 7. It should work for this case.
You can then run Crease to duplicate vertices and create a crease if you need.
I hope this helps, thanks,
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
Hi, thanks for the update. Is there an equivalent to the SelEdgeLoop function in RhinoCommon? Trying to incorporate it into a C# function…
