how to split a mesh by faces or selected edges? can a new SubD tool help? or should it be done in Gasshopper?
Hi @YuSh,
There’s a SelEdgeLoop command in Rhino 7. It should work for this case in Rhino.
You can then run Crease to duplicate vertices and create a crease.
Thanks,
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
Perhaps Rhino8 will be the genius of Chebyshev’s mesh design? While this is possible with the help of kangaroos and other algorithms. It is a pity that it is impossible to use panels tools and lunch box. Such a tool or plug-in is required to actually produce ribs of equal length on any surface.
