Hi all,
i have created a net from parabolas that I am mirroring and moving a varying number of times with hoopsnake. I now want to select all curves from all iterations to split them with the rectangle and all touching parabolas. It only selects the latest created items though as the pictures show below.
Really appreciate all suggestions on how to do it.
Thanks for the idea! That would have been an easy solution. But it doens’t do what I need it to. The curves are partially intersection. Behind that tool is probably the interpolated curve tool, I guess and that doesn’t work for me. I need the curves to be touching exactly to do structural Analysis with it. That’s why I created parabolas.
Still having the Problem and really hoping to find a solution soon.
Then probably you should post some file.
solved the issue by using Anemone. But thanks!
