I am working on some details and there is a problem with section filling. On the screen it looks fine, but when printed it goes weird, as on attached pictures. The display mode is the hidden view, altered a bit (with the original is the same problem). Solid fills are completely gone, hatch fills are broken. The objects are solids. I know the problems with printing to a PDF format, but maybe this one could be connected to the Open GL presentation?
Rhino screen:
Hi Jaro,
Can you send that model to visualarq@asuni.com? We can check if we experience the same problems and find a solution.
What VisualARQ version are you running?
Thanks,
I have the same problem. All the hatches show fine but when I go to print some sections of hatches show up and some don’t. I have the latest update of VisArq 2.10.2.14727
