Secondary Osnaps not selectable / working
Hi @curtisw
The secondary (or sub?) Osnaps which are shown when ctrl or command is pressed are not selectable. Some of these can be activated via the command line. For example OnMesh but most are not available. Or do I miss something?
Jess
Hey @Jess,
Sorry I’m not sure what’s going on there. @Trav do you have any ideas?
Are you in a command? Both of those key states require that an active command is running for the option to be selectable.
Hi @Trav
Yes, in commands - and it looks like some work, some don’t work.
For example this works:
Command: _Points
Location of point object: _PersistentOnSurface
Select surface
Location of point object. Press Enter when done ( Undo )
Command: _Polyline
can’t pick the _PersistentOnSurface option from the OSnap dialog
but I can input this option in the command line.
Other commands don’t even accept the command line option
HTH, Jess
Hi Jess -
That seems to work as expected here.
Please post your SystemInfo.
Hi @wim
I did some more testing and maybe the problem comes from my Logitech keyboard? When I press the CTR key to access the sub-options then these show up but cannot be picked.
When I use the command key then it works like expected. Can’t test it with Apple keyboards right now. Anyways time to train my muscle memory…
Thanks,
Jess
Hi Jess -
Thanks for that additional information.
RH-90223 OSnap: Dialog: Control Provides Inaccessible Options
RH-90223 is fixed in Rhino WIP
