Hey folks! hope yall are having a wonderful day! i wanted to ask about this beautiful screen i found on pinterest. i tried making it manually but im not getting nice results through sub-D. is there a way to model it through Grasshopper? (without voronoi method)
Hmm, just throwing in some ideas. Depends a bit on how much control you need for the end result. You could give tOpos plugin a try for an “Organic” look, but I can imagine will take the same amount of time if not longer to properly set up than trying it with sub-d. Maybe with Kangaroo some rough input mesh + anchors + pressure component and smoothing the result in the end.
So I guess if I would need to use GH I’d try it with tOpos for generating the base and then modify the result to my liking.
thanks alot for the reply felix! I am trying to create a product line and prototyping is a pain when doing through SUB-D as it just takes too much time. hence by grasshopper i was hopping to automate the process to some extent. i will try the tOpos Plugin!
