How to unify surface uv direction in GH?
I used brep select SubD but them uv direction are disorderly,what can l do to unify them?
You probably used mirror to create your wall? I think it would be easier to directly create your wall with a grasshopper definition.
im a tyro, it is a subd wall and i want to take use lunchbox to make some panels. :pensive:
Sorry, I don’t quite understand your project but I think that if you want to import geometry from rhino, your geometry from rhino must first be unified in rhino
Why don’t you try this component by @Iker
Example file image
Cheers,
BVR
I think you tagged the wrong person. You probably wanted to tag Iker Mugarra(I don’t tag him, since I do not see why that would help).
Is it ?
Update: Yes, you’re right it is @iker.mugarra
I tagged him for crediting, nothing else.
Thank you very much,this is good tool for me :grinning: :grinning:
