Dear Altruist,
I am quite in Rhino. I have created a both side leader line. When I zoom in those, it is perfect, whereas when I zoom out those it is messy. How can I fix it?
Dear Altruist,
Hello - if you use the Arrowhead command for this (?), these are screen based arrowheads and will do what you show.
You can make dimensions with no dimension text - it seems like it would be tedious with the current system but possible by making one, and then using Orient (Copy=Yes, Scale=1D) to place the copies.
Thanks for your reply. Can I fix this Arrowhead? or is the only solution is no dimension text?
Hello - no- that is, it is behaving as designed - it is not meant to scale with the view.
