I am trying to draw a section line in a detail by using the arrowhead command, but the arrowhead scales when I zoom in an out. The arrowheads at the ends of dim strings keep their size when I zoom and when I print- how can I get these other arrowheads to be static too?
Hi Lawrence - Arrowhead only makes screen size arrowheads, you’ll need to work around with a leader(s) or something.
Lawrence, I use arrowhead all the time for section lines. Agreed, they look horrible in model space when they go scale crazy, but when you go to print your pdf, you can easily adjust the size of the arrowheads in the print dialog. Not a perfect solution, but it works.
