Every time in the past few days I have not been able to save my rhino files. It just stops responding and gives me no error codes. The only way I can get out of it is to force close the program. There are autosave files but I am unable to save as, save small, or regular save. I tried updating my nvidia and intel drivers also updated windows and rhino. My license is not expired. Does anyone know what could be wrong and how to fix it?? Thank you
Welcome @lenardln
Please run the Rhino command _SystemInfo and post the results here.
Rhino 6 SR33 2020-12-8 (Rhino 6, 6.33.20343.16431, Git hash:master @ d492bef53a3f6a576db4d197feaaa7ddf0c7a653)
License type: Educational, build 2020-12-08
License details: Cloud Zoo. In use by: Laura Lenarduzzi ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: MSI
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-5-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P3200 (NVidia) Memory: 6GB, Driver date: 1-22-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.40
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-22-2021
Driver Version: 27.21.14.6140
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.33.20343.16431
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.33.20343.16431
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.33.20343.16431
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.33.20343.16431
C:\Users\lenar\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino6.Plugin” 0.0.20090.750
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.33.20343.16431
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.33.20343.16431
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
Hi Laura
Try repairing the Rhino 6 install: Start Menu > Settings > Apps > Rhino 6 > Modify > Repair
Okay, just tried that but it didn’t work either.
Hello - are you saving to the local hard drive, a network, or a synced folder like DropBox etc? Does it work to save to the desktop?
I usually save to a local hard drive. I just tried to save it to the desktop but it still crashed.
Hello - if it hangs and does not crash, please do this:
While Rhino is in this state, start windows Task Manager and locate Rhino in the Processes page
Select it, right click, and choose ‘Create dump file’. When it is done, it will tell you where that is - locate the file, Zip and upload it on www.rhino3d.com/upload to my (Pascal) attention. Please include a link back here in your comments.
When I attempt to right-click while Rhino is not responding, it doesn’t allow me to select “create dump file”. Should I attempt to do this before I attempt the saving in Rhino?
Hello - it looks like you have multiple Rhinos running, is that correct? Click that arrow and see - do you exepct all of these? If not, I’d close all of these, (with End Task) and start over, maybe after a reboot with only one Rhino running. Maybe reboot as well for good measure.
I see you have VRay and Lands - if the problem persists, please disable these in Options > PLug-ins page and close and restart Rhino. Does it still happen? And when/if it does, does it happen if you make a brand new file, make a box and Save?
Once I clicked the arrow I was able to create a dump file but now I am having trouble uploading it to the link you posted because it is telling me the form isn’t secure and when I tell it to send anyway it does nothing. Is there another way I can send you the zip file? Also, just for reference, I included the picture of the rhino drop-down arrow. I am unsure of why all of the vray files are open and I also don’t know how to fix that, besides just disabling the plug-in. Also, I don’t think I want to disable Lands because I am directly using it in this file.
Hello - so, the save problem is related to one particular file, correct? If Rhino crashes saving it, then presumably there is nothing to be lost in opening it without Lands and Vray running and seeing if the save works. Please disable Lands and Vray, reboot the machine, to clear the decks, and open the file and see if you can save it.
So, I just tried that and it, unfortunately, didn’t work. I did also create a new Rhino file with simple geometry and it allowed me to save. I then tried to save a file that has much more complex work in it and it allowed me to save. But when I go back to the autosave file I have been attempting to save, it still doesn’t work. Could it somehow be related to it being an autosave file?
Hello - so to be sure: without Lands and Vray , you opened the file but could not save, correct? Can you please start Rhino and run Audit3dmFile on this file and attach the results?
Correct, with both Lands and Vray disabled, it didn’t save.
Here is the audit info
Testing 3dm Archive: D:\Documents\University of Cincinnati\2021_1 Spring\Thesis 2\West Creek Deisng (67712) RhinoAutosave.3dm
Start Section: 453 bytes (offset 0 to 453)
Offset: 0
3dm archive version: 60
Interface Name: Rhinoceros 6.27 - Educational, build 2020-06-24 - (compiled Jun 24 2020)
SDK Version: 2348836105.2355918193
OpenNURBS Version: 2355918193
3dm Version: 6
Operating System: Windows 10.0 SR0.0 or greater, 64-bit, platform 0, version 10.0 build 0 sp 0.0, suite 0, product type 0
Runtime: ON::RuntimeEnvironment::Windows 3DM I/O processor: OpenNURBS toolkit version 2355918193 (compiled on Jun 24 2020)
Properties Section: 314 bytes (offset 453 to 767)
3dm archive openNURBS version: 2355918193 (6.27 2020-06-24:1)
Application Information:
URL: “http://www.rhino3d.com”
Details: “Educational, build 2020-06-24”
Revision History:
Create Time: Wednesday January 13 16:26:01 2021 UCT
Last Edit Time: Friday February 05 02:43:49 2021 UCT
Revision Count: 13
Created By: “lenar”
Last Edit By: “lenar”
Settings Section: 21574 bytes (offset 767 to 22341)
Model length unit system: inches
Page length unit system: millimeters
Plug-ins:
Name: 3Dconnexion 3D Mouse
Version: 6.27.20176.05001
File: C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp
SDK Version: C++ 2348836105.2355918193 (6.0 2017-08-15:1, 6.27 2020-06-24:1)
Name: Adobe Illustrator Export
Version: Jun 24 2020 05:25:09
File: C:\Program Files\Rhino 6\Plug-ins\export_AI.rhp
Version: Jun 24 2020 05:25:06
File: C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp
Version: 6.27.20176.5001
File: C:\Program Files\Rhino 6\Plug-ins\Commands.rhp
SDK Version: .NET 0.0
Version: Jun 24 2020 05:26:32
File: C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp
Version: 0.0.20090.750
File: C:\Users\lenar\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino6.Plugin.dll
File: C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp
File: C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp
Version: 5.3.2.6637
File: C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Lands.rhp
SDK Version: C++ 2348836105.2352508657 (6.0 2017-08-15:1, 6.14 2019-05-07:1)
File: C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp
Name: Renderer Development Kit
Version: Jun 24 2020 05:22:51
File: C:\Program Files\Rhino 6\Plug-ins\rdk.rhp
Name: Renderer Development Kit UI
Version: Jun 24 2020 05:24:25
File: C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp
Version: 1.50, Jun 24 2020, 05:23:56
File: C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp
File: C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp
Version: Jun 24 2020 05:27:13
File: C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp
Version: 19.0.2.17067
File: C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Tibidabo.rhp
File: C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp
Name: V-Ray for Rhino
Version: 4.20.02 ( May 5 2020 )
File: C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp
SDK Version: C++ 2348836105.2354869133 (6.0 2017-08-15:1, 6.23 2020-02-24:1)
Embedded image Table:
0 embedded images, 24 bytes (offset 22341 to 22365)
Texture Mapping Table:
mapping[0]:
mapping[1]:
mapping[2]:
mapping[3]:
mapping[4]:
mapping[5]:
mapping[6]:
mapping[7]:
mapping[8]:
mapping[9]:
mapping[10]:
mapping[11]:
mapping[12]:
mapping[13]:
mapping[14]:
mapping[15]:
mapping[16]:
mapping[17]:
mapping[18]:
mapping[19]:
mapping[20]:
mapping[21]:
mapping[22]:
mapping[23]:
mapping[24]:
mapping[25]:
mapping[26]:
mapping[27]:
mapping[28]:
mapping[29]:
mapping[30]:
mapping[31]:
mapping[32]:
mapping[33]:
mapping[34]:
mapping[35]:
mapping[36]:
mapping[37]:
mapping[38]:
mapping[39]:
mapping[40]:
mapping[41]:
mapping[42]:
mapping[43]:
mapping[44]:
mapping[45]:
mapping[46]:
mapping[47]:
mapping[48]:
mapping[49]:
mapping[50]:
mapping[51]:
mapping[52]:
mapping[53]:
mapping[54]:
mapping[55]:
mapping[56]:
mapping[57]:
mapping[58]:
mapping[59]:
mapping[60]:
mapping[61]:
mapping[62]:
mapping[63]:
mapping[64]:
mapping[65]:
mapping[66]:
mapping[67]:
mapping[68]:
mapping[69]:
mapping[70]:
mapping[71]:
mapping[72]:
mapping[73]:
mapping[74]:
mapping[75]:
mapping[76]:
mapping[77]:
mapping[78]:
mapping[79]:
mapping[80]:
mapping[81]:
mapping[82]:
mapping[83]:
mapping[84]:
mapping[85]:
mapping[86]:
mapping[87]:
mapping[88]:
mapping[89]:
mapping[90]:
mapping[91]:
mapping[92]:
mapping[93]:
mapping[94]:
mapping[95]:
mapping[96]:
mapping[97]:
mapping[98]:
mapping[99]:
mapping[560]:
561 texture mappings, 249669 bytes (offset 22365 to 272034)
Material Table:
material[0]: Earth Image
material[1]: Earth Image
material[2]: Earth Image
material[3]: Earth Image
material[4]: Earth Image
material[5]: Earth Image
material[6]: Earth Image
material[7]: Earth Image
material[8]: Earth Image
material[9]: Earth Image
material[10]: Earth Image
material[11]: Earth Image
12 materials, 15558 bytes (offset 272034 to 287592)
Linetype Table:
linetype[0]: Border
linetype[1]: Center
linetype[2]: DashDot
linetype[3]: Dashed
linetype[4]: Dots
linetype[5]: Hidden
6 linetypes, 1360 bytes (offset 287592 to 288952)
Layer Table:
layer[0]: Default
layer[1]: Proposed Full Trail
layer[2]: Site 2
layer[3]: Clipping Planes
layer[4]: Path
layer[5]: Clipping Planes
layer[6]: Section 1
layer[7]: Topo Lines
layer[8]: By Parent
layer[9]: Terrains
layer[10]: Satellite Image
layer[11]: Creek
layer[12]: Make2D
layer[13]: Visible
layer[14]: ClippingPlaneIntersections
layer[15]: By Parent
16 layers, 4108 bytes (offset 288952 to 293060)
Group Table:
group[0]: Group02
1 groups, 153 bytes (offset 293060 to 293213)
Annotation Style Table:
annotation style[0]: Dimension Style 01
1 annotation styles, 1433 bytes (offset 293213 to 294646)
Light Table:
0 lights, 24 bytes (offset 294646 to 294670)
HatchPattern Table:
hatchpattern[0]: Solid
hatchpattern[1]: Single
hatchpattern[2]: Double
hatchpattern[3]: Hatch1
hatchpattern[4]: Hatch2
hatchpattern[5]: Hatch3
hatchpattern[6]: HatchDash
hatchpattern[7]: Grid
hatchpattern[8]: Grid60
hatchpattern[9]: Plus
hatchpattern[10]: Squares
hatchpattern[11]: Hatch 1x45
hatchpattern[12]: Hatch 1x0
hatchpattern[13]: Hatch 2
hatchpattern[14]: Hatch rhombus
hatchpattern[15]: Hatch rhombus new
hatchpattern[16]: Rhombus
hatchpattern[17]: Rhombus (band) 1
hatchpattern[18]: Rhombus (band) 2
hatchpattern[19]: Rhombus (band) 3
hatchpattern[20]: Rhombus (band) 4
hatchpattern[21]: Rhombus (band) 5
hatchpattern[22]: Rhombus (band) 6
hatchpattern[23]: Rhombus (band) 7
hatchpattern[24]: Rhombus (band) 8
hatchpattern[25]: Rhombus (band) 9
hatchpattern[26]: Rhombus (band) 10
hatchpattern[27]: Rhombus (band) 11
hatchpattern[28]: Rhombus (band) 12
hatchpattern[29]: Hatch33
hatchpattern[30]: Hatch Dash
hatchpattern[31]: Rectangle 5 2
hatchpattern[32]: Rectangle V 5 2
hatchpattern[33]: Double window 5 2
hatchpattern[34]: Double window vertical 5 2
hatchpattern[35]: Brick flooring 6 3
hatchpattern[36]: Brick flooring 2 1
hatchpattern[37]: Fish bone 2 1
hatchpattern[38]: Fish bone 3x1
hatchpattern[39]: Hexagon
hatchpattern[40]: Octagon 1
hatchpattern[41]: Wall 23 5
hatchpattern[42]: Star hexagon 1
hatchpattern[43]: Star quad 1
hatchpattern[44]: Asterisks new
hatchpattern[45]: Asterisks Par
hatchpattern[46]: Triangles
hatchpattern[47]: Star hexagon 2
hatchpattern[48]: Star hexagon 3
hatchpattern[49]: Star hexagon
hatchpattern[50]: Star-Cross
hatchpattern[51]: Quad flooring with course 10_1
hatchpattern[52]: Quad flooring with course 10_0.5
hatchpattern[53]: Wall 20_5 with course 1
hatchpattern[54]: Wall 20_5 with course 0.5
hatchpattern[55]: Hexagon New
hatchpattern[56]: Hexagon with course 0.5
hatchpattern[57]: Hexagon with course 0.2
hatchpattern[58]: Hexagon with course 0.1
hatchpattern[59]: Octagon with course 0.1
hatchpattern[60]: Octagon with wide course
hatchpattern[61]: Rubble
hatchpattern[62]: Circles
hatchpattern[63]: Circles (thick)
hatchpattern[64]: Dodecagon by thick circles
hatchpattern[65]: Dodecagon by sparse circles
hatchpattern[66]: Dodecagon by star circles
hatchpattern[67]: Star from circles
hatchpattern[68]: Star hexagon new
hatchpattern[69]: Star new sparse
hatchpattern[70]: Star hexagon New connected
hatchpattern[71]: Star dodecagon 1
hatchpattern[72]: Star dodecagon 2
hatchpattern[73]: Star dodecagon 3
hatchpattern[74]: Star daisy
hatchpattern[75]: Star thick daisies
hatchpattern[76]: Triangles close distance
hatchpattern[77]: Triangles average distance
hatchpattern[78]: Hexagon 4
hatchpattern[79]: Star 4
hatchpattern[80]: Flowers 1
hatchpattern[81]: Flowers 2
hatchpattern[82]: Flowers 3
hatchpattern[83]: Flowers 4
hatchpattern[84]: Flowers dodecagon 1
hatchpattern[85]: Flowers dodecagon 2
hatchpattern[86]: Flowers dodecagon 3
hatchpattern[87]: Flowers dodecagon 4
hatchpattern[88]: Flowers dodecagon 5
hatchpattern[89]: Flowers Blue bottle
hatchpattern[90]: Flowers Blue bottle 2
hatchpattern[91]: Flowers Blue bottle circle only
hatchpattern[92]: Flowers Blue bottle 3
hatchpattern[93]: Flowers Blue bottle 4 with stem
hatchpattern[94]: Flowers Blue bottle stem
hatchpattern[95]: Flowers Camelia
hatchpattern[96]: Flowers Camelia 1
hatchpattern[97]: Flowers Camelia 1b
hatchpattern[98]: Flowers Camelia 1 plus
hatchpattern[99]: Flowers Camelia 2
hatchpattern[100]: Flowers Camelia 3
hatchpattern[101]: Flowers Camelia 4
hatchpattern[102]: Flowers Camelia 5
hatchpattern[103]: Flowers camelia 2 plus
hatchpattern[104]: Flowers Camelia-Dahlia
hatchpattern[105]: Flowers Dahlia
hatchpattern[106]: Flowers Dahlia 2
hatchpattern[107]: Flowers daisy
hatchpattern[108]: Flowers daisy with stem
hatchpattern[109]: Flowers double daisy
hatchpattern[110]: Flowers double daisy 2
hatchpattern[111]: Flowers daisy (thick)
hatchpattern[112]: Flowers daisy 2
hatchpattern[113]: Star 5
hatchpattern[114]: Flowers daisy 3
hatchpattern[115]: Concentric quads 2
hatchpattern[116]: Concentric quads
hatchpattern[117]: Concentric quads 3
hatchpattern[118]: Concentric quads 4
hatchpattern[119]: Concentric quads 5
hatchpattern[120]: Periodic quads
hatchpattern[121]: Rectangular tiles 4x1
hatchpattern[122]: Rectangular tiles 4x1 with course
hatchpattern[123]: Windows/frames
hatchpattern[124]: Windows/frames 2
hatchpattern[125]: Star/circle
hatchpattern[126]: Parquet (random)
hatchpattern[127]: Connected quads 1
hatchpattern[128]: Connected quads 2
hatchpattern[129]: Quad 5x5
hatchpattern[130]: Quad 1x1
hatchpattern[131]: Quad 5x5 ing.
hatchpattern[132]: Quad 5x5 flooring
hatchpattern[133]: Rhombus flooring
hatchpattern[134]: Octagon flooring
hatchpattern[135]: Flowers hexagon
hatchpattern[136]: Flowers hexagon 2
hatchpattern[137]: Flowers 6
hatchpattern[138]: Flowers 5
hatchpattern[139]: Flowers hexagon 3
hatchpattern[140]: Flowers hexagon 4
hatchpattern[141]: Flowers hexagon 5
hatchpattern[142]: Flowers Octagon 1
hatchpattern[143]: Flowers Octagon 2
hatchpattern[144]: Flowers Octagon 3
hatchpattern[145]: Flowers Octagon 4
hatchpattern[146]: Flowers Octagon 5
hatchpattern[147]: STAR Octagon 5
hatchpattern[148]: Checkerboard (white)
hatchpattern[149]: Checkerboard (black)
hatchpattern[150]: Fishbone flooring (white)
hatchpattern[151]: Fishbone flooring (black)
hatchpattern[152]: Fishbone flooring 1 (white)
hatchpattern[153]: Fishbone flooring 1 (black)
hatchpattern[154]: Fishbone flooring 2 (white)
hatchpattern[155]: Fishbone flooring 2(black)
hatchpattern[156]: Exterior flooring
hatchpattern[157]: Entwined flooring (hexagonal)
hatchpattern[158]: Entwined flooring q1
hatchpattern[159]: PANEL q1
hatchpattern[160]: Entwined flooring q2
hatchpattern[161]: Entwined flooring q3
hatchpattern[162]: Entwined flooring q4
hatchpattern[163]: dodecagonal asterisks
hatchpattern[164]: Roof tiles
hatchpattern[165]: 16facet circles 1
hatchpattern[166]: 16facet circles 2
hatchpattern[167]: 16facet circles 3
hatchpattern[168]: Rooftop (flush tiles)
hatchpattern[169]: wave 1
hatchpattern[170]: Wood rooftop (flush tiles short)
hatchpattern[171]: Rubble 2
hatchpattern[172]: Road top with flowers
hatchpattern[173]: Wood tile rooftop (short)
hatchpattern[174]: Fans
hatchpattern[175]: Tile rooftop
hatchpattern[176]: Tile rooftop 2
hatchpattern[177]: Tile rooftop 3
hatchpattern[178]: Pentagonal Star
hatchpattern[179]: Pentagonal Star new
hatchpattern[180]: Quad mesh
hatchpattern[181]: Drops
hatchpattern[182]: Intersecting drops
hatchpattern[183]: Intersecting drops 2
184 hatchpatterns, 281868 bytes (offset 294670 to 576538)
Block Definition Table:
block definition[0]: name = “*U{173f6ee8-006b-4303-99aa-bceea13aa648}” id = 6bd79f6c-838a-4f9d-bd8e-c78abffbf88f
1 block definitions, 9373 bytes (offset 576538 to 585911)
History Record Table:
0 history records, 24 bytes (offset 10326695 to 10326719)
Model User Data Table:
user table[0]: (8594 bytes)
Plug-in name: Renderer Development Kit
Plug-in id: 16592D58-4A2F-401d-BF5E-3B87741C1B1B
user table[1]: (913 bytes)
Plug-in name: AnimationTools
Plug-in id: 3AA81848-5635-41bb-ABDB-0EC069BC5519
user table[2]: (8267996 bytes)
Plug-in name: Tibidabo
Plug-in id: 3F5C54C8-2A32-49a9-ADE2-79E489B8060B
user table[3]: (497 bytes)
Plug-in name: Rhino Render
Plug-in id: 5DC0192D-73DC-44f5-9141-8E72542E792D
user table[4]: (260 bytes)
Plug-in name: Enscape.Rhino6.Plugin
Plug-in id: AD538828-DFB1-46da-8ACE-55E7208ECDCD
user table[5]: (22940 bytes)
Plug-in name: V-Ray for Rhino
Plug-in id: E8CFE179-B60C-411a-8416-62A893334519
user table[6]: (9506 bytes)
Plug-in id: 8008880F-8D13-4b2d-92B0-727E12878A4C
7 user tables, 8311413 bytes (offset 10326719 to 18638132)
Archive size = 18638152 bytes (end mark size = 18638152)
The object table was too many characters to include. Do you need this info? Also, I don’t know if this really solves my problem because it may still happen in the future, but I was able to copy the content of the file into a blank file and it allowed me to save. So, I guess that is always an option if this does happen again
Can you run Audit3dmFile on both and save these to text files? I am curious about what the difference might be.
West Creek Design.txt (58.8 KB) West Creek Design AUTOSAVE.txt (126.7 KB)
Here are both the audit text files
Thanks - Autosave has a lot more objects
1173 objects with 6 plug-in data items, 9740784 bytes (offset 585911 to 10326695)
vs.
610 objects with 6 plug-in data items, 4413976 bytes (offset 316075 to 4730051)
were there hidden or off objects when you dumped everything over to the new file?
It looks like these were in block definitions. Does the new file you created look correct when opened with Lands and Vray enabled?
It looks the same but maybe there are less objects because I copied and pasted with both plug-ins disabled. But no, there weren’t any hidden or off objects.
