I’ve just purchased the Rhino 6 for Windows upgrade and have been having trouble saving. I only noticed this because I was periodically getting “Autosave failure” in the command history. When I tried to save my file, I got an even more worrying notification
Any ideas on what’s going on here? I don’t want to just export my model because then my layouts and associated settings will be lost. Help would be greatly appreciated.
Another possibility we are seeing a few of is in Windows Defender > Virus & Threat protection > Virus & threat protection settings > Make sure “Controlled folder access” is Off.
This sounds more like your eval version thinks it’s expired. Other people having the file save problem have reported that saving under another name, copying/pasting or exporting still works.
Hello - just to confirm - saving to say, the desktop, works, is that correct? And Autosave - does this fail always?
can you run the Autosave command a few times - what happens?
Autosave was running automatically and I think it had failed for about 400 minutes or something. In the end, I was able to save the file out as Rhino 5, and I’ve been working in Rhino 5 ever since.
I believe this is a real bug - nothing to do with the evaluation. @thomasn 's problem is a problem with (it would appear) Rhino 5 annotation styles imported into Rhino 6 (possibly in a linked block). We are still working on the solution.
When is this problem going to be solved?
I had to stop testing Rhino 6 because i have to import Rhino 5 files quite often, and if the problem occured, there is no other way than to close the file without saving, which is really annoying…
I have the same problem. I’m using the commercial version Rhino 6.
When I try to save my file to hard disk or Dropbox, i receive the error message “Rhioceros 6 Failed to Save”.
For me the workaround was to save the file to Rhino5 file format.
Hi there,
i have the same issue here, and i can’t save or export or event copy/paste the drawing i did.
I am scared to lose 3 hours of work (which can be redone but…).
Any idea of what is going on ?
Spec :
Rhino 6 pro on Windows 10
I am in between Google Drive and a servor.
