@Helvetosaur
@mikko
I have hoped and prayed since posting this that I missed a setting, I dont experience the 'adjustment is needed after a while,…instead the slightest mouse movement and my item whips off screen, thats USELESS IN THE EXTREME.
It was essential I fix it and back up PC today.
THIS WAS SO VERY FUNDAMENTAL, I AM ALWAYS MOVING ABOUT AND ROTATING ABOUT WHERE MY MOUSE IS, CONTINUALLY. I CAN AS MY WORKFLOW NEEDS, DO SO AS IF FLYING A SPITFIRE, YOU THINK IT AND IT DOES IT SORT OF THING.
there are times it does whip about, its not repeatable , but zooming into an item sees rotation about that item.
Now we have to select that zoom tool and draw a box.
THIS IS BROKEN, Msoft are supposed to break things that worked, but not McNeel.
The slightest movement and my item area of interest I rotate about is GONE OFF SCREEN.
Thats not adjust every so often. After the box is drawn I find generally its staying within vision.
Q1. Can a keyboard shortcut be made to place a box screen centre, saves for reaching for another tool losing the tool one was working with ?
The zoom box is get zoom tool, drag box, rotate the object, readjust after a few moves, repeat, pan, repeat the whole process. getting hold of the tool one was using after dragging box each time.
Takes ages compare to when no other tool was needed in V5.
Flying a Fairey Battle v Spitfire !
Q2. I see no Zoom>selected, where is that ? Though selecting to rotate spoils the view especially if I was after doing a printscreen of colours, and not eisking deletion or moving things.
V5 rotated about where one had panned to, in other words it rotated about the screen centre knowing that the object in your vision nearest you, was your wanted item, this V7 rotates about as if the object is somewhere in the distance ! why would anyone be interested in rotating an object far away. The foreground gets thrown off screen immediateley, well almost, its at edge of screen in a mm of mouse move.
Hi Jarek,
So we’re talking about this:
I need to uncheck that?
Thx, --Mitch
Q3. but you say tick it ?
Q4. also I cant see post#6, forum doesnt put numbers to posts any more (broken) but counting them one has only 5 and the other #6 is nothing aha moment.
This is very disappointing, makes me now want to carry on with V5.
Its a function I did VERY OFTEN without thinking.
Q5. Another thread on this problem suggests View Set camera Place Target, that then gives rotation about the object targeted. Means targeting each item that is at end of mouse, and even more clicks before rotating the object.
To have to navigate an entire menu and sub menu is too long winded.
What would be the script for a Ctrl+K key for this ? that should speed things up.
Q6. What also is the antidote as I have used set target a few times since V4 and cannot then undo it for a general object rotate.
V7 has been a struggle, taking ages, recreating Document Properties per Template by hand, adjusting to suit inches or mm or metres, recreating RhinoOptions one setting at a time.
Today was D Day, 2 weeks late in my win10 Rhino install build (rebuild in fact,.July went wrong win10 acting up right left and centre, now I have all new hardware, and I am skint), today was critical, all I need to do is fix the 3D rotate then I can declare V7, on what I have found so far, acceptable and do an Acronis back up, (only backup working, not with notes on faulty added to it !) then try for referencing scripts and so on, then back up again, then continue with win10 build as now 3 weeks behind thanks to 2 weeks V7, having to manually set up V7 in all settings, and a week to solve Outlook advanced find not working, also screen saver and solve Msoft breaking the Recent Places VITAL option for saving to a folder from wherever one wishes to. (Browsing each time to do a save is very slow workflow)
V5 is all as it was, and its lovely.
This V7 issue wont get fixed anytime soon if ever.
Backup and use V5 perhaps.
Steve
