I have an aircraft fuselage and its dead easy to see port or stbd, nose area etc. No chance of me thinking I am looking at port when its stbd.
With Rhino you move the mouse to the right and the view rotates as if its on a turntable rotating anticlockwise.
Imagine a postcard carousel, you push on its right side and it rotates anticlockwise.
Thats normal and good.
I can have that happening, stop rotating, click on ortho window, do some work, click perspective to rotate it anticlockwise again and this time it goes the other way.
Right click perspective name and choose perspective and we are back to normal !
I am not accidentally flipping the view, I am just going to it as I have done thousands of times since using rhino v4 and pushing the view anticlockwise by right mouse button down and move mouse to right on mousemat. but V5 is performing fine, then I can do that move again, and its fine, might be 10 times I do that, 50 times, then 51 and it goes the opposite way, I am still looking at port side, but mouse to right now gives clockwise. If I had flipped the view over I would see the stbd side.
I have been working solely on the port side. I closed the file like that last night. Opened it this morning and still showing port side, start to rotate it and its going the opposite way…i.e its going clockwise when it should have gone anticlockwise.
I cant say anymore, I hope this has explained it.
Default rhino mouse right rotates view anticlockwise, mine does so, then decides to go clockwise with the next time I do the anticlockwise move, that next time might be 10 moves later, or 50, or 1
I did a printscreen but PC hasnt put it onto clipboard, never had that before either.
I will describe it in its normal state, grey line heading NW is y, vert is Z, line heading NE is X
when it misbehaves I shall report back again with what that looks like.
MC Escher optical illusion.
aware of that, Photomodeller does the inversion flip, but as I rotate you get to see what is what what moves past what and with a bit of rotating you get your bearings and see it has mirror image flipped, port side of aircraft is now mapped onto stbd and vice versa.
Steve
