RiR - Wall Location Line
Can we have an option for the Wall Location Line inside AddWall.ByCurve component? I remember when I was testing Archicad - Grasshopper connection long time ago and lack of this option was very frustrating.
Modifying the Wall Location Line by Element.ParameterSet changes Location Line in the Properties, but the wall stands still and doesn’t adapt to those changes.
I will investigate if it is possible to add this option to the AddWall.ByCurve component.
It seams that modifying the Location Line after creating a wall is no what you expect. In fact, if you change the Location Line in the Revit UI itself behaves exactly equal as using Element.ParameterSet to do so. It just modifies the location of the control points of that wall not the wall location itself. You can read more on this issue here.
I agree about modifying the Location Line after creating a wall. In Revit then you can just flip the wall around axis. Maybe flip boolean toggle would be useful in that case?
But to have quick access to the Wall Location Line before constructing a wall is crucial.
Let’s say I want to draw a simple corridor 150 cm wide. Right now I would need to measure the difference between the wall axis and wall face and offset construction lines to compensate space taken by the walls - it seems like an unpleasant workaround.
I hope it can be added.
Done.
Please update an tell me if it’s what you expected.
Amazing speed :D. That is it!
Minor detail - if we modify the Axis curves, Revit’s Aligned Dimension made from wall core to wall core updates nicely to it, but made between wall faces disappears.
Minor detail is fixed now too.
Indeed, dimensions stay where they should, but I noticed regression between previous version and the current one in something much more important. In previous version, the distance was as expected. In current, in Rhino, distances are measured between wall centerlines instead of faces.
Take a look at the thick green lines in Rhino viewport.
Current version:
Previous version
What about now?
I think I finally found how to do it.
Hello Kike,
Now it seems to do what it should, at least for me and at least in that case.
However, after those changes, I think that input names are misleading.
Axis is no longer axis of the wall but Location Line and the bottom Location Line input should be named something like Location Line Type.
It is a quite crucial component and needs deep consideration if there should be more inputs or outputs.
For example, Core Boundary lines output, Axis of the Core output.
Architects and engineers of the forum, share your opinions!
EDIT:
Oh boy, bad news.
Now wall moves, but don’t flip.
Good point about the Input names, but before change this, I want to thinking more if we should have the LocationLine input here or we should create a new component to edit walls LocationLine, that allows you to change the alignment and flip the direction in case is necessary. This new component will be able to edit existing walls as well.
Does it make sense?
At first glance it does.
Could modifying walls alignment and flipping direction afterward be performance heavy - like double the work to compute?
In general, I agree that components shouldn’t be too general, have too many options, or too big.
I don’t know what is your vision about Grasshopper in Revit in general, but one of my biggest concerns is that it should be very fast and with the use of as little as possible clicks/components to achieve trivial results in Revit. Because if we make this path unnecessary long, then in bigger projects it stacks up.
Trivial scenario:
Corridor - two walls facing the same wall finish inside. Corridor clearance - 150 cm.
About the performance will be the same.
Revit API have no way to directly create a wall using an other LocationLine than Axis, so, right now are already two operations but in one component.
Having a second component is necessary for editing existing walls, so the question is if is a good idea having same functionality on two different components. I’m not sure it is.
More opinions are more than welcome.
By now I’m going to move this functionality to a new component to keep name consistency as well as allow changes on existing walls in the model.
We can always copy this into AddWall component again later.
I will be happy to test any new approaches to this problem if you will have something.
Is there any option for a newsletter when the new RiR build is released?
EDIT:
I just noticed this tiny gray text. Anyway, although I always type my e-mail address I do not receive any newsletter about new RiR Build.
There is a new version available here.
Could you please test AddWall.ByCurve again?
I am on vacation but I quickly tested it on my laptop.
It seems that I ran into some problems on the same start - curve input. It looks that only one segment of the polyline is creating the wall.
Polylines are not supported, Revit walls should be created using a Line or an Arc.
I will improve the error message.
Previously, I always used polylines and they worked just fine. Did you discover some new problems with polylines?
The component never accepted polylines that are not line like, you can double check it in the source code.
Maybe you were splitting polylines in Grasshopper before feeding this component in your definition, but never directly a polyline. So nothing new in that aspect is just the way Revit works.
Now I see that in 2020 it also accepts ellipses, but no luck for polylines anyway.
You are right. I forgot about exploding and there wasn’t any warrning so I got confused.
So far looking good! Thanks for all the effort.
I can’t see Stacked Walls among Element Types.
