I have a simple grasshopper graph to import some geometry from revit from a view, for some reason it seems that the Query Elements module stops working. I need to delete it and replace it. It way have to do with the limits feature which I deactivated by clicking on the minus sign. Anyone have a similar issue or know of a solution?
Hi Benjamin,
I haven’t seen this reported or in action.
Can you provide your about info as well as details about your environment (BIM360, Central on intranet, local file,…)
This is with a local file. Let me see if this issue happens again (and the issue with the duplicates) once I upgrade to the newer release candidate.
