Rhino - Revit connection lost between sessions
Pretty obvious (and painful) limitation, every time I reopen RiR, connection between my Grasshopper input and generated geometry inside Revit is lost. Can we maintain the connection someway? Are there limitations/problems that I am not aware of? It would be welcome if you could explain it a bit.
Thanks.
It seems that also the recompute creates duplicate revit elements in the same place. The problem also exists during the creation of ElementTypes: if I create an element type of a family, at the next opening or after recompute an error notify the duplicate type.
Hey. Thanks for the report. We are working on a way to handle element bindings gracefully and provide APIs so scripted components can also avoid duplicating elements. Will keep you posted.
Filed an issue for this to be take care of
Thanks! This will be a huge step forward.
Looking forward to it, would be extremely helpful!
