RIR Issue with Create Toposolid – Boundary Incorrect at One Point
I am trying to import a Toposolid into Revit using Grasshopper. I have done this multiple times before, always encountering different issues that I usually manage to solve. However, this time, the boundary that I output to the Create Toposolid component seems incorrect at only one point.
I’ve checked my inputs and logic, but I can’t find an obvious mistake. I suspect this might be a bug in the Create Toposolid component.
Has anyone else experienced this issue? Any ideas on what could be causing it?
Rhino.Inside Revit: 1.24.9005.13660 (2024-08-27T07:35:20)
Rhino: 7.38.24338.17001 (Rhino 7)
Revit: 2024.1.10 (24.1.10.25)
CLR: 4.0.30319.42000 (4.8.9290.0)
OS: Microsoft Windows NT 10.0.26100.0
You can find the Revit file and Grasshopper file attached. Thanks in advance for any insights!
geo-test.rvt (7.2 MB)
ground-bug.gh (22.2 KB)
There was a fix a while back for points that were on the border. I’ll take a look at your file this afternoon.
https://www.rhino3d.com/download/rhino.inside-revit/1/latest/
A quick look seems ok, unless i am missing something?
Yes, using the latest version everything is alright. Sorry to bother.
