I have a set of closed boundary curves. the create toposolid component doesn’t seem to work for me:
contours.3dm (123.3 KB)
Just extrude (contour interval height), cap and solid union…
I identified one open curve, deleted it, and get the following new error now:
I don’t want the geometry to be stepped, it should interpolate the curves smoothly.
I did the following:
Note I did not use the lowest open contour (in red) for the patch because that would have resulted in a mess, it being vertical (and even slightly inside of) with the next one up over a portion of its length.
Thank you for clarifying. How would you bring this into Revit with grasshopper?
Thanks,
Charlie
Hi Ct.Rhino,
Similar to how you add points to the Toposolid via the Revit UI you will need to do so as well in Rhino.Inside.Revit.
The definition above should have worked with your file.
Attached is a internalized version.
R8-RiR-Toposolid-Internalized.gh (23.6 KB)
When creating a Toposolid via the Revit UI you create a profile (bottom crv)
then add points, the Revit API creation is no different.
I understand now, only the “boundary” curve goes into the top curve container.
Thank you! I am very excited to have this working. On to hardscape.
@Japhy I am having a hard time getting my new landscaping into the model. I suspect it has something to do with the number of points.
The script seems to make a lot of extra points on my blended surface
I am sharing the contour geometry here.
contours.3dm (283.6 KB)
and ten seconds later… I played with the tolerance and got it to work.
