Problem with Creating Toposolid In Revit by RIR
Hello friends, I am super new to Rhino inside Revit and I am struggling with creating toposolids in Revit using a polysurface from Rhino.
I am not sure what is the most efficient way to do this. I first create a poly surface in rhino, and i use a Brep component to select it
Then I use Edge and Edge Divide components to get points from this surface.
Then I extract the boundary border, using the flat surface below. And use a Curve component to select it.
Finally I connect the boundary curve and the edge points to the Add Toposolid components. But I get an unwanted result. Looks like all generated ramps are tring to tie back to the flat surface below. I can’t figure out why, can someone please help?
I am hoping RiR will help me with modeling terrains in revit, currently I am importing all revit toposolid into rhino to get reference surfaces, then I bake them and start to model all the slopes and shapes, after all that I want to transfer the surfaces back into Revit as toposolids. If there is a better way to do this please let me know.
creating toposolid.gh (7.5 KB)
RHINO FILE.3dm (513.3 KB)
The rhino and grasshopper files are attached, thanks in advance!
Did another test, this time I try to use the Host shape component, same trail, I use a brep to capture a larger base surface as the boundary input, and edge points as point input. The result is similar - multiple surfaces stacking on each other…
failed host shape.gh (6.0 KB)
host shape test.3dm (723.6 KB)
you just need to Flatten the Points.
Similarly Here @Yiming_C
What can I say, THANK YOU!!!
