Rhinos Can Fly, WASD game engine fly camera controls for Rhino
demo
Check the github: GitHub - Viterkim/RhinosCanFly: Flying camera controls for Rhino 3D (raw input, wasd, keybinds) · GitHub
Pigs might fly? Well rhinos do now.
WASD or weird binds flying camera for Rhino in perspective view. Windows only (sad trombone noises, Rhino doesn’t like supporting Linux).
Extras
It only hijacks right click when in perspective view, and still allows commands with right click when doing edits (for confirming etc).
Blender says no, Rhino also says no, but we’re gonna do it anyway and intercept right click at an extension level, and pass it on depending on context (very nice).
Do you want hammer source1/source2 ish old level editing camera controls, or modern game engine (unreal engine / unity / godot) camera controls? No? Just Me? Well ok…
I recommend going to Tools → Options… → Mouse, set middle mouse button to Manipulate view and rotate.
I also recommend setting lens length in your file/project/default rhino setup to something like 18 or so, which gives that 100 FOV feel. (Not in the addon options, that’s a temp toggle).
Run / Commands
RhinosCanFly main command, fly around in perspective view, exit on right click and escape.
RhinosCanFlyOptions pops up a panel where you can change keybindings / features (same menu is also in Tools → Options… → Rhinos Can Fly).
RhinosCanFlyInit is only used at startup to not have delay going into the view the first time.
Main Install
Install via Yak in Rhino.
In Rhino run PackageManager then find RhinosCanFly → install and restart.
It works with Rhinoceros v7?
I would love to make it work for v7, but i don’t have it and i only have the evaluation version of rhino 8 now :confused:
I also fixed a bug with the toolbox/text hanging around while hovering over the gumball, i’ll add a bit later.
I guess maybe i can try to make it work for rhino 7, then you can clone the repo and make a build? (Then we can maybe even upload it and it can work for more people for version 7).
I don’t think i can download rhino 7 with only an evaluation license.
Ok updated to 0.1.1
As i don’t have rhino 7 i can’t try it out, but it should be there in the package manager, on github releases, and on Food4Rhino when it gets aprooved. Try it out and tell me if it works.
cleanup rawinput
fix text toolbox getting stuck (gumball etc when in fly mode)
fixup the build scripts
rhino 7 support
runtime float rounding
Updated to 0.1.2 (github, rhino package manager, food4rhino)
redid options / settings
support non repeating commands
make mouse input / keyboard movement not polled (make it smooth)
add hacky mouse 4/5 (side button) support to do the same as the middle mouse button (pan or whatever you set in rhino mouse options)
Updated to 0.1.3
movement speed fix related to unit/grids (different files / projects would make the speed weird)
build cleanup
artistic logo (thanks to Peter and the amazing ms paint skills)
edit 0.1.4
undo the speed relative to units (it didnt work properly, and cant, was a bad cplane relative hacky thing, also tried with document settings but its not reliable and can change depending on setups)
still has bug fixes from 0.1.3 etc
Updated to 0.1.5
(had some F# issues but they are gone oh well)
save/load speed on document support/toggles
fly mode and rotate camera issue fix (especially with gumball)
initial cross platform setup
win forms to eto ui (cross platform)
the issue was basically rotation + enter fly mode and raw input was starting before rotation finished, so it missed the release and for gumball rotation there were some issues as well so now it just waits for the drag to end and THEN flies.
still not cross platform, all the mouse/raw input stuff is windows only, but atleats its segmented now and the ui/settings isn’t windows forms anymore
updated on github, and PackageManager/Yak (so also Food4Rhino)
https://www.food4rhino.com/en/app/rhinos-can-fly-rhinoscanfly-flying-custom-perspective-view
Updated to 0.1.6
rhino 9 alpha support
fix slow gumball hiding
smoother mouse look with direct camera
reduced start delay
Food4Rhino does not seem to show the rhino 9 versions of stuff yet, but is available on github/the package manager.
I spent a lot of time debugging why rhino 9 mouse input felt bad, and haven’t found a fix/think something is wrong with rhino 9 itself (as it also happens on normal pivoting), but this version does atleast work on rhino 9.
Posted here
and here Bug: Rhino 9 has worse viewport/ui/scheduling which is 'not smooth/laggy' - #2 by Gijs
EDIT: was not the issue was my plugin that hit a thing in rhino9 that changed and exposed some issues, so my bad!
Updated to 0.2.0
rhino 9 support
raw mouse input in own thread
fixed mouse lag inconsistent sens (missed input)
same rhino 7/8/9 flight and redraw paths
cleanup
ended up fixing it after i posted stuff in other threads about issues i hit (sorry)
Updated to 0.2.1
support for right click can enter fly while doing stuff (a command, go back and forth)
keyboard pivot controls while flying ('z' and 'x' by default)
shift or alt + right click pivot and pan
improve mouse 4/5 and pivoting
hide gumball while flying option
cleanup
added viewport redraw modes for temp debug performance issues (after doing many things in rhino9, even after then flying for the first time the performance seems worse, its very hard to manually trigger, so i've made this to troubleshoot stuff more long term)
So basically optional stuff and workflow improvements. The pan/drag stuff can be nice once you get used to holding shift (if enabled) before right clicking etc (still relies on the middle mouse button being set to pan).
Updated to 0.2.2
fix pivot binds spinning weirdly depending on speed
add middle mouse/mouse4/mouse5 toggle pivot while flying
added toggle mode for mouse 4/5 pivoting (held mode still exists)
different multipliers for key pivoting and fly mode mouse pivoting
fix flying speed leak from previous file into new file (only runtime state)
fixed (alt pan) and mouse override state weird stuff
regroup mouse options in the menu
Updated to 0.3.0(will be a breaking config change)
optimize mouse 4/5 input
optimize raw input
fix tooltip cleanup when entering fly mode
add lens length delta option
add pivot binds while flying
fix gumball hiding bug
remove allocations in hot loops
redid the options menu / settings
add 'RhinosCanFlyPivot' and 'RhinosCanFlyPan' commands (non flying basically, just toggle variants of normal rhino stuff)
Updated to 0.3.1took ages debugging an issue.
the big one, fix right click flight entry sometimes freezing and making the UI white (issue with Rhino.UI.MouseCallback + mouse button + cancel up/down, it might be broken with a rare race condition)
add RhinosCanFlyTempFly, temporary default flight modes and a cancel/go back bind
add toggle and hold pan binds with separate pivot and pan multipliers
add geometry and distance targets for pivot, pan and flight exit
fix mouse 4/5 only starting after moving the mouse
fix pivot and pan snapping, gumball movement, target selection and cleanup
fix keyboard and mouse ownership and raw input cleanup
improve config saving and options
make viewport and flying smoother
Updated to 0.3.2
new cmd RhinosCanFlyToggleEnable to toggle the plugin until restart
add object center target for pivot (like an invisible gumball)
fix movement keys sometimes staying held after flying
fix the cursor sometimes moving after exiting flight
fix geometry targeting hits
fix active document and viewport checks
Updated to 0.3.3
camera when pivoting could jump (while flying and pivoting), fixed
fix zoom not working when flying + pivoting
options/rhinoscanflyoptions menu saves scroll position for the runtime now
Hi, Can you make your plugin work with parallel projection as well?
Hmm how would it work / how would you want it to work?
Isnt parallel the ortographic mode where we wouldnt be able to move back and forth, even if we moved the view back and forth we wouldnt be able to see a difference.
So you want panning movement on the movement keys, and move up / down to zoom? (likely seperate binds for these so people can choose what they want)
No, what I’m talking about is the 3D isometric viewport. Watch the video below.
Ye exactly, but the problem is the way a perspective projection works is, that no matter the distance from the camera, it looks the same. The camera shoots out parallel rays, so no matter where the camera is it will look the same.
So when it zooms, it doesn’t move the camera closer, it changes the projection scale.
If i turn it off the check for only perspective mode, we can move to the sides and up and down, but back/forwards doens’t do anything visually.
So i guess the user experience people would want, would be that we zoom in/out on back/forwards right?
TLDR, you want to feel like you are getting closer with back and forwards, even in parallel view right?
Yes.
