Hi all,
RhinoLands/Lands Design 6.4 is available for download !
This is a minor update with just a few improvements and error fixes. However, since it takes advantage of some new stuff introduced in Rhino 8 Service Release 23, it requires Rhino 8 SR23 or higher in order to install.
Here is the complete what’s new list:
Plant List
- Shrubs, Groundcovers, and Topiaries are now listed with an icon closer to their appearance in the drawing
Plant 3D Display
- The possible presence of roots is now taken into account when adjusting the plant scale to achieve the desired height
- Foliage color now has some transparency
Performance
- Terrain is now evaluated only once when calling context menu commands on several Terrain Input Data objects (like disabling all divisions at once from the Divisions root node)
Error Fixes
- Plant photo was not being updated in some cases when changing its image
- Walls along a polyline path curve were not properly adjusted to terrain
- Objects elevated to terrain were not automatically updated when modifying the hardscape terrain (like ramps)
- Creating a Groundcover from a circle could crash Rhino
- Fatal error when trying to change the color of Zones with a different initial color
- Fatal error when purging blocks inserted from the library
- A bad triangle appeared at the origin when computing the terrain base box in AutoCAD
- Recent files named with non-ASCII chars were not being shown in RhinoLands Ribbon’s File menu
Notes
- Supported Rhino versions
- Rhino 8 SR23 or later, and
- Rhino 7 SR33 or later
- Supported AutoCAD versions
- AutoCAD 2026, 2025, 2024, 2023, 2022, and 2021
Enjoy it!
