I’m using the new Rhinoceros 7 Wip version.
I’d like to have a close volume, easily offset it and keep a subdiv volume.
That’s why I try the new Quadmesh tool.
When I use it without choose “Convert to SubD” everything is ok.
But when I swish it on, all edges are wavy and nothing is close.
There are a couple of things happening here. The wavy edge syndrome is coming from enabling Interpolation on the SubD object when its being converted. Unchecking Interpolate SubD will certainly fix that. The other thing that you’ll want is for the edge vertices to be creased as well since this is an open SubD and currently the QuadRemesher does not do this (and it should) to SubD objects.
Yes it will only affect the open edges. I used this example as it was simple to explain and try. Obviously you can crease any or all edges that need creased. Where people often get stuck with creasing is on those edge vertices. They don’t crease by default but should.
