quad remesh cannot creases edge surface! for Subd
rhino7.0.20042.09575
crease.3dm (116.0 KB)
@BrianJ
@wim
Hi - If you ask me, that’s a case where QuadRemesh needs some thickness to figure this out - see:
@Trav will be able to set me straight if that’s not the case.
i think need to hardEdge option to QuadRemesh
@wim is right, there’s no crease info in the original extrusion object that can be applied to the new subd object when its created.
i think need HardEdge or {corner} option to Quadremesh for SurfaceSubD (sharp outline Edge) similar (new)grasshopper Quadremesh component option
I’ve added this to the pile here.
