Rhino8 changes, right clicks not working, and no Render panels?
Hello, I am noticing a few changes to what I can access with mouse clicks in Rhino 8.
First thing I noticed today is when I right click on the layers in the bottom-center panel, it no longer lets me Select Objects or other things like it used to do. Now I have to go the right side, go to the Layers over there, and then do it. Small thing, I know, but not as quick.
Also, it looks like we have to type commands to access all the Render stuff, like Materials, etc. now? Why is this? Just frees up program space or something? Less typing is good, because sometimes people only have one functional hand. I mean both of mine work, but theoretically, one might not always work.
Hi CarvedMetal,
Can you post your systemInfo? (via Rhino command line)
Not seeing this…
This might be related but not exactly sure what you mean, a little more detail on your workflow would be helpful. Thanks
Hello, here are some pictures of the Rhino8 window and my PC info at work (actually I should see if it does the same thing on my home PC tonight…). So on the right side tabs the right-click does show the layer options, but on the bottom center Layers tab right-clicking does nothing. thank you for taking a look and any suggestions!
Oops, just saw via the Rhino Command Line. Here is my System Info using that…
