Rhino.inside - Rhino window right click on layer doesnt work
Right click on all layers (native to current rhino file and worksession file) doesnt show me the menu options. I checked in a regular rhino 7 file and right clicking on layers works in it. This problem is consistent with all rhino.inside files I have atm.
Using Rhino 7 and Revit 2021.1.6
Hi @srujan.v16,
Are you talking about this context menu?
Hi @kike thats correct. This menu doesn’t show up only when I use Rhino.inside with revit 2021 and RHino 7. Havent cheked other revit versions yet.
srujan, I’m not able to reproduce this.
Can you provide more detailed system info
As well as the info that typing in SystemInfo in the Rhino command line provides. Thanks
Rhino 7 SR17 2022-4-12 (Rhino 7, 7.17.22102.05001, Git hash:master @ 13b57035af8fb22da005ef72c56e4555d9dbcfe3)
License type: Commercial, build 2022-04-12
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Super with Max-Q Design (NVidia) Memory: 8GB, Driver date: 3-17-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.15
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2022
Driver Version: 30.0.15.1215
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\svichare\Documents\Grasshopper_Plugins\elefront500\Elefront500\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Mindesk\Rhinoceros\Mindesk.rhp “Rhinoceros® Link for Mindesk”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22102.5001
@Japhy
Please let me know if you need anything else. Cheers
Srujan V16,
Can you see disable the Elefront and Mindesk via Plugin Manager and restart your Rhino.Inside.Revit and see if layers are behaving as expect?
And to confirm, you aren’t seeing this behavior in a standalone Rhino session?
Thanks
Hi @Japhy ,
Thanks for the advice. I am not sure if its the latest rhino.inside update that dropped today or the disabling of plugins but it worked. I can access the layer context menu now.
And to answer your question, this behaviour/issue only appeared with revit and rhino.inside. Standalone Rhino is working well.
Cheers
Edit : Spoke too soon
@Japhy
The context menu problem is back.
Also noticed other context menus display out of proportion
It goes beyond the edge of the screen
Can you go down to one display to trouble shoot this? The setup (resolution & alignment) of the multiple displays might be a factor. Thanks
