In Rhino WIP, I cannot right-click on the Layers Panel to “Select objects”
this method does work in Rhino.Inside WIP, but not in the normal application.
Also, it is nice when the interface layout remembers it previous panel docking configuration (not in either Rhino WIP)… for example, that I had the Layers Panel on top of the Properties Panel with the Layer Names pulled out to be readable… Is always like this image upon opening new:
This seems to be working fine here. Is the menu appearing when you right-click on a layer?
Please run the Rhino SystemInfo command and copy-paste the result here.
Sorry, I have the last public build 7.0.20189.15345, not the most recent.
Yes, I right lick on a layer and there is no dialog box. Works in Rhino.Inside Revit, not in Rhino WIP.
Select by Layer> “choose layer” works ok.
If you don’t have any monitors plugged into your Intel 630 (change it if you do), then you can DISABLE the Intel display adapter in Device Manager.
That’s what I’ve done myself.
