Rhino8.8 Layout dialog clipped controls
请看截图,文字显示不全
微信图片编辑_20240709091641
我这边没有发现类似的问题,
你的屏幕显示比例有使用缩放?
我使用 Win11 操作系统测试,有些设置会影响显示内容:
I tested with the Win11 operating system, and some settings may affect the display content:
  1. 如果你使用的是高分辨率屏幕,屏幕分辨率缩放建议使用推荐值,不要自定义缩放数值。
    If you are using a high-resolution screen, it is recommended to use the recommended screen resolution scaling, rather than customizing the scaling value.
  2. 有些用户觉得 Rhino 界面文字显示很小,会去调整文本大小缩放:
    Some users find the text displayed in the Rhino interface to be very small and may try to adjust the text size scaling:
    你可以从下图中看到不同的文字缩放会影响弹窗上的元素显示:
    You can see from the images below that different text scaling can affect the display of elements in pop-up windows:
建议你排查下你的电脑设置,看看能不能解决问题。
I recommend checking your computer settings to see if you can resolve the issue.
没有缩放,
字体大小都
是 系统默认的
@悠哉游哉 pls run _SystemInfo in Rhino and post back the results. Edit: just see you already posted those earlier.
Rhino 8 SR8 2024-6-18 (Rhino 8, 8.8.24170.13001, Git hash:master @ c3cc7c123163b65d85b517aff795627d5b12166b)
License type: Commercial, 版本2024-06-18
License details: Stand-Alone
Windows 11 (10.0.22635 SR0.0) or greater (Physical RAM: 48GB)
.NET Framework 4.8.9241.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P4000 (NVidia) Memory: 8GB, Driver date: 5-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.55
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-23-2024
Driver Version: 31.0.15.5255
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
d:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24170.13001
d:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “网页浏览器”
d:\Program Files\Rhino 8\Plug-ins\rdk.rhp “Renderer Development Kit”
d:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino 渲染” 8.8.24170.13001
d:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24170.13001
d:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp “Snapshots”
d:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24170.13001
d:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24170.13001
d:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24170.13001
d:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
d:\Program Files\Rhino 8\Plug-ins\Displacement.rhp “Displacement”
d:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp “SectionTools”
@curtisw do you have a clue what might cause this? To me it appears that in the screenshot of the user, the padding between the controls is larger than what you see on @jessesn ‘s screenshot.
设置 应该是没有问题的,
hi @悠哉游哉
I could not repeat it here on my end, but logged the issue:
RH-82955 Chinese dialog for layout is clipped
建议你对显卡驱动予以升级,并且把显卡设置都恢复成默认,以查看能否解决相关问题。
It is recommended that you upgrade the graphics card driver and restore the graphics card settings to default to see if the relevant problems can be solved.
RH-82955 is fixed in Rhino 8 Service Release 10
@悠哉游哉 这个问题已经在 Rhino8.10 候选版中修复,你可以点击这里下载后进行测试
感谢, :+1:
不客气,麻烦帮忙测试下,看看这个问题是否已经修复。烦请告知,谢谢
微信图片编辑_20240724170744
的确已经解决.另外就是印象中,以前双击一个物件,会弹出属性面板,现在要用属性 只能自己点开了?这个是逻辑改了 还是在哪可以设置哦??
一直就没用过,除非你用了第三方的插件。
