Tiny (like, miniscule) Menu Font + UI overlapping?
Anybody else getting this UI issue? I’m up-to-date with the most recent service candidate RH8. Updated my graphics studio driver. Issue persists. Making it a little difficult to work, so a quick fix would be highly appreciated, thanks!
Oh, worthy of mention: I can’t grab the main container and resize its height. Tthe splash screen is tiny, as well. And the Command line, too, tho I’ve bumped it up 1.5 so it looks normal.
FYI my windows settings are as they normally are, where it’s 150% using a 4K monitor.
SysInfo
Rhino 8 SR22 2025-7-20 (Rhino 8, 8.22.25201.15001, Git hash:master @ a60ea0aa8b370a66a674d35be5fc1120ca466d4c)
License type: Commercial, build 2025-07-20
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.18
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4080 (NVidia) Memory: 16GB, Driver date: 7-14-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 577.00
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 7-14-2025 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-14-2025
Driver Version: 32.0.15.7700
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.1.0
C:\Users\alanf\Dropbox\Rhino_MasterDB\packages\8.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
C:\Users\alanf\Dropbox\Rhino_MasterDB\packages\8.0\Garage\8.7.24140\net7.0\Garage.rhp “Garage” 8.7.24140.15431
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\byRhinoGadget\1.4.5\byRhinoGadgetPlus.rhp “byRhinoGadgetPlus” 0.0.0.0
C:\Users\alanf\Dropbox\Rhino_MasterDB\packages\8.0\OVFP-Rhino-UE-Bridge\0.7.4\OVFP Rhino UE Bridge.rhp “OVFP Rhino UE Bridge” 0.7.8600.22536
C:\Users\alanf\Dropbox\Rhino_MasterDB\packages\8.0\Cephalopod\0.0.3.0\Cephalopod.rhp “Cephalopod” 0.0.1.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.22.25201.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.22.25201.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.22.25201.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.22.25201.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.22.25201.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.22.25201.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.22.25201.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.22.25201.15001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
  • Alan
To me this doesn’t seem to me like an issue that is caused by anything in Rhino. When did this start happening? Do you have any Font scaling in parallel to Windows Display scaling active?
No. It just started happening yesterday when I posted. Usually I have two monitors going and now I’ve had to move my system and start it up with only one, but can’t imagine that being the reason.
Checked other programs and doesn’t seem to be an issue with them. Plus, it’s strange that it’s my entire UI that’s being affected - not just some of the font sizing. I can’t grab my upper containers to resize, and some of my containers aren’t even showing up, even if I reset my saved window setups.
I haven’t tried doing an install repair, so I guess that’s next, followed by a safe start of Rhino sans plugins, and then a fun trip down the rabbit hole of whether a recent Windows update affected my system.
Alan
Repair fixed the issue. Text and UI working fine again. SysInfo below. Thx for the quick reply as always.
SysInfo
.NET 8.0.18
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
