I was wondering if there’s an easy way to create a transparent solid hatch?
As of now, I can only create transparency through gradient hatch types.
And as a workaround, set both start and end stops to the same color and transparency.
…and it seems that is the only way to determine hatch color also - if it’s different from the layer color.
No, you can make a regular solid hatch and then either change the layer color to have transparency or set the display color to a “other” color with transparency.
Hi All - in V7, colors can have alpha values in hatches apart from the layer color- just edit the object display color for a solid hatch in Properties -
this also works in gradient hatches if you edit the colors inside the hatch controls, though the workflow is a little convoluted.
