Transparency and layers
I see there’s a transparency setting for layers in Rhino 7, but setting it does not make a default solid on the layer transparent.
Is there a trick I’m missing?
Hello - it only affects objects that are layer colored - not sure if that tells you anything for your case…
It doesn’t seem to make hatches transparent, and I can only find gradient choices for transparent hatches.
Hm… hatches obey here…
I should have said that they won’t print transparent - at least not from Layout space. They’ll display transparent, yes.
Would be good to know if this is a problem anywhere else.
Hello - it does not happen here - most likely it is related to GPU and drivers, I suppose, can you please run the SystemInfo command in Rhino and copy/paste the results here?
Rhino 6 SR34 2021-2-3 (Rhino 6, 6.34.21034.07001, Git hash:master @ 2fec8130f097ca52a8bc9f334c3ed4a5921c5e30)
License type: Commercial, build 2021-02-03
License details: Cloud Zoo. In use by: David Grantham ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: LAPTOP-19DBBOQS
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 10-17-2017 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 7-5-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 451.67
> Integrated acclerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: None
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-5-2020
Driver Version: 27.21.14.5167
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2018.9.26.937\SectionTools.rhp “SectionTools”
Transparent color support on layers and objects is a Rhino 7 feature.
Rhino - Features
– Dale
Yes. that’s where I’m having the trouble. But I posted the system info from Rhino6 by mistake. Oops. Here’s the RHino7 system info:
Rhino 7 SR5 2021-4-10 (Rhino 7, 7.5.21100.03001, Git hash:master @ 2cd158094b595f6400479d7cbe511454b6149527)
License type: Commercial, build 2021-04-10
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21100.3001
I guess I’d start with disabling VA once again, close and restart Rhino, and see of that affects it.
(Your Intel GPU driver is also very old, I’d update that to the latest available from the Intel website, whether or not it affects this issue…)
Thanks. On a test today it printed to pdf with transparency with and without Va, so maybe I got my settings confused before. That old display driver is current though.
