I have Rhino6 and i can’t print to PDF. On rhino5 i used adobe no problems other than i had to max out the quality to get a respectable print resolution. With Rhino 6 there is a couple of problems. Most importantly i can’t print with Adobe or PDFcreator because it crashes rhino6. Also in the image preview it doesn’t show what i have in paper space but shows wireframe so my assumption is that even if it did print it wouldn’t print what is visible in paper space. I did get a error log with Adobe which i’ve pasted here:
%%[ Error: syntaxerror; OffendingCommand: --nostringval-- ]%%
Stack:
/buildcrdname
%%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
%%[ Warning: PostScript error. No PDF file produced. ] %%
At this point there seems to be so many bugs that i can’t use rhino6 for actual work. The bugs are for functions that worked fine with Rhino5.
I just installed the latest version 6.6 and my adobe no longer crashes and i can actually print a pdf. However i can’t seem to print what i see in paper space. For example in paper i normally have a custom display mode i created which is similar to shaded but more crisp which in Rhino5 results in a much more clear print out on paper. When i try to print now from adobe the image is in wire frame. As a test i did one detail in my custom display mode, 1 in shade, 1 in arctic and 1 in wireframe. What prined some wireframe not from wire frame and a big black square. I uploaded the result as well as a screen clipping so you can see what didn’t print.Rhino 6 - Screen Clipping (as PDF).pdf (113.9 KB) test2 to delete.pdf (75.2 KB)
